- Aug 26, 2011
- 15
- 0
- 0
martins8585 said:Knowing nothing about electronics (apart from it's not a good idea to make toast in the bath......) is there anything to be gained from buying the OEM part vs the cheaper option?
martins8585 said:Hi - I hope I'm not doubling up on the PSU thread below but I'd like some advice on replacing the transformer in my amp.
I've got a Parasound A23 which I picked up 2nd hand and although I love the sound it does have an annoying hum from the transformer. (Tried all the usual tricks, tightened restraining bolt, put some rubber sheet under the transformer etc)
I've been quoted £200 for an OEM transformer however my local TV repair shop have said they can source a none OEM transformer that will supply the correct voltages etc for around £90.
Many thanks.
Alears said:martins8585 said:Hi - I hope I'm not doubling up on the PSU thread below but I'd like some advice on replacing the transformer in my amp.
Many thanks.
I would have to say yes.
As the other PSU thread indicates the whole amplifier was built around that PSU . If you replace it with a non OEM version, irrespective of identical outputs etc., you may not get the same sound you are use to.
Was the quote of £200 from Parasound themselves?
Not knowing the price of this amp new I would suggest if you are happy with it then get them to service it.
If not flog it on rather than fit a non OEM version.
Many thanks.
Many thanks.
