I really like the Audiolab 8200CD, the Marantz PM6003 amp and the KEF Q300 speakers, all of which I have managed to hear, but never together. Would they work as a system for rock and reggae mainly ? Thanks
JezBaker said:Try demo all the stuff if you can
Jacko said:I really like the Audiolab 8200CD, the Marantz PM6003 amp and the KEF Q300 speakers, all of which I have managed to hear, but never together. Would they work as a system for rock and reggae mainly ? Thanks
Jacko said:Would they work as a system for rock and reggae mainly ?
Mr Morph said:Jacko, in my opinion there is no way that the Pearl is on a par with the Audiolab. And if I was you I'd stick to your original plan. I actually thought that the system you suggested could well surprise you with the quality. Sometimes you need a starting point, live with it for a while, and then decide where to go next. Better that, than spending a load of money and ending up with a sound you utterly hate. And unlike some, I think you can get a really good sound by mixing both low and high end components! And for the record, my DAC was engineered by the same guy that did the Audiolab, and my Marantz does warm the sound up!
brittondave said:Mr Morph said:Jacko, in my opinion there is no way that the Pearl is on a par with the Audiolab. And if I was you I'd stick to your original plan. I actually thought that the system you suggested could well surprise you with the quality. Sometimes you need a starting point, live with it for a while, and then decide where to go next. Better that, than spending a load of money and ending up with a sound you utterly hate. And unlike some, I think you can get a really good sound by mixing both low and high end components! And for the record, my DAC was engineered by the same guy that did the Audiolab, and my Marantz does warm the sound up!
Yup and that's why it's such a personal thing, because I think the Marantz is on a par with the Audio lab.
maxflinn said:i think spending that much of your budget on a cdp is the wrong thing to do, if it were me i'd budget about £800 for speakers, £600 for an amp (that figure will buy you a very good one) and i'd get a 2nd hand cdp for £100, there's loads to choose from on ebay, a cdp has the least impact on a system, you could upgrade that last, and you probably wouldn't need to upgrade speakers or amp.
alternatively,you could look at getting a dac, i've got a v dac and when connected to my blu-ray player the sound produced is better than the marantz cd6003 that i had before. they can be got for about £140 and any transport, dvd/blu-ray player/ ps3 etc can be used with one.
maxflinn said:hi dave, how i see it is.
a cd has the stored digital data that a dac converts, any spinner is more than capable of reading all that data and sending it to a dac, that's easy.
the dac then plays its part, the better it decodes the digital data the better the end sound, irrespective of amp and speakers. but i have my doubts as to how much dacs differ, in fact i believe they differ very little, so imo a decent cheap, used cdp makes more sense.
also, cheapish dacs like the vdac or spitfire are quite capable, the record spot has said that the spitfire gives better sound than his cd7001ki sig (which would be in the audiolabs class), so i personally don't see the point in the op spending north of £700 on the cdp when a different route will free up money for better componants that will deliver better sound immediately, no waiting for money for upgrading, no buying and selling either.
