Got the A5s today.
First impressions: Wow they are tiny floorstanders, quite a bit smaller than the MA RS6s. Quite a bit narrower and shorter. Interestingly in the specs both say 15cm/6inch drivers. MA's drivers are actually 14cm across and A5's only 12cm!!! What kind of measurements are these? I think Spendor didn't increase the drive size from 14 to 15cm from S5e to A5 - they just massaged the specs!
Fit and finish lacks way behind MAs. Patches of glue can be seen on the plastic cones and the wood finish is nowhere as smooth and nice as that of the RS6s. In the looks department, the MAs definitely have the upper hand. Although I do like the fact that speaker cable terminals are at the bottom of the speakers as opposed to up high like on MAs.
First I plugged the Marantz 7001Ki. Not a very good partner I will tell you! The sound was totally off. As good as the Marantz sounded with RS6s, with A5s it was not at home.
Next came the Kandy K2. Different story here. Kandy drives the speakers much better. I noticed treble was quite forward and immediately thought my rock music will sound terrible again (as it did with Kandy+RS6 combo). But I was (somewhat) wrong, even Disturbed lean sounding new album was listenable. Red Hot Chili Pepper's Californication still sounds terrible - but that's a terrible recording with ear-pinching guitar. I next played Depeche Mode's Perfect (from the new album) and switched back and forth with RS6s. The sound with RS6s was much fuller, bass extended and plentiful. A5s sounded a bit boxy and lean. I remember Igglebert's comment about SA1's "The treble is to die for".... well I do like the treble on the A5s but I can't say I have noticed a massive difference over RS6s yet. Metallica's "Nothing Else Matters" though sounded absolutely sublime and so did Diana Krall's "Boulevard of Broken Dreams".
Thus initially I am a slightly underwhelmed (admittedly I've only had them for about 2 hours). Dynamics and speed are there. The soundstage is wider. Voices sound great. Speed certainly improved from RS6s, at the expense of the bass - which is my biggest issue with them. The bass is there alright, it's just it's less than 1/2 what RS6s delivered (albeit slightly sloppily). Maybe RS6s had just spoiled me.
Being relatively inefficient, you have to crank up the volume to get a punch out of the A5s. They also seem like they are working really hard to get the room filled with music.
Now I am following the advice given that I should give them time - as initially they may not impress. Well now that I have committed to selling the RS6s (buyer picking up soon) I do have time...
