The Sound of Not Quite Silence
ESP2009
177
On the back of a couple of threads I've noticed about 'white noise' and 'hiss' from speakers, I shall ask what is probably a daft question.
If, as has been the general response, the presence of such when the amp is on, but nothing is playing, is considered to be of no great cause for concern, am I right in assuming that if you can hear what is coming from your source, even with the amp turned to minimum, the same applies?
Over the past few weeks I have, off and on, had cause to run the CDP, DAC and amp on a 24/7 basis to burn-in various I/Cs have been trying out. Naturally, I have had the volume on absolute minimum. However, when all is quiet in the house, it is still possible to hear the sound of whatever track is currently playing (a bit disconcerting at first, when you don't realise where the sound originates - I thought the voices were back!) Fortunately, she who thinks her hearing is far more sensitive than mine doesn't appear have noticed this phenomenon.
This tempted me to switch the CDP player off and check both extremes on the amp volume: at minimum there is a definite gentle background hiss when you do the unnatural and place ear close to the speaker; this is very slightly greater when you hit maximum. Logic tells me that the sound of the CDP being audible at minimum volume is part of the same phenomenon.
It also begs a question: is this level of throughput adequate to burn-in speaker cables? (Believers only need reply).
I welcome your opinion.
I wouldn't worry about it. If you are trying to burn-in interconnects then you don't need the speakers connected so you won't hear anything through them. I think it's normal to get some noise through the speakers when the amp is on and nothing is playing. Obviously the higher the volume you would expect to hear more noise through the speakers.
If you have a hi-fi why not just listen to music at normal volume, giving you the best of both, cable burn-in (assuming it happens) and you get to listen to your favourite tunes which is what the system is for!
Enjoy 🙂
