The Dynavector 10X5 is in
jcarruthers
26
Fitted and aligned the new cartridge today — really need to get the VTA sorted as the arm is a little bit too laid back.
Set it to 2.0g
Need to play a few records to run it in — feels quite detailed at the moment with little surface noise.
Happy so far…
James
CJSF
251
Set it to 2.0g
Happy so far…
James
Be patient on the run in time.
Here is a set of shims with a new 'gap idea' to make it easier to fit them, no need to remove the arm? :?
http://www.ebay.co.uk/itm/ISOKINETIK-3-POINT-VTA-SHIM-SPACER-6MM-KIT-FOR-REGA-3-POINT-TONEARMS-RB301-RB202-/181165367586?pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item2a2e4c2122
CJSF
stevebrock
183
no fella - but I have Gus's subplatter here!
I have just got a replacement Brand new full price RP6, no wobble - just gonna let it settle down then try the subplatter over the weekend!
My 10x5 isn't even run in yet!!
Steve, with the 2mm spacer in, does your lid shut without touching the counter weight?
stevebrock
183
jcarruthers said:
I bought the Michell Engineering Tecnowight to enable me to close it — I hope!
ooo err - heard it a nice little upgrade!
oops - upgrading a Rega - need to keep it quiet around these parts!
jcarruthers
26
Damnnnn Chebby — I wish I had seen that before. Oh well…
Added a 2mm spacer this evening — a grown man can scream when the sub platter knocks off the needle guard as the arm swings loose — luckly it kind of pinged off and pushed the arm away.
Note for next time — masking tape to keep things in place or remove the cartridge first!
jcarruthers
26
Also — either I have gone a tiny bit deaf in the last few days or rasing the arm at the back has made things quieter — pretty sure the amp is closer to 10 o'clock than 9 o'clock
I'm not going to say it sounds better because I'm pretty sure there's some bias in there :)
jcarruthers
26
I've not been around for a few days so haven't spun that many records since fitting it — so I've only put about 4 or 5 hours play on it — it's great so far :)
stevebrock
183
Got about 20 hours on mine, dunno when they start to open up! but sounds good at the min - if anything a little forward or it could be my new amp :)
drummerman
540
Sounds like you have a lovely system there now you're back in the church of Rega. Are you going to post pictures?
regards
stevebrock
183
Just noticed your not using the Rega Protractor?
I was advised use the protractor for the arm you are using!
It looks fine to me JC but I could be wrong!
Regarding pick up of dust, I dont find it any different to the Exact tbh
stevebrock
183
