The best substitutes for the B&W P5s
JSerra
I've owned two sets of P5's and they both got returned due to the fragil cable that made me only listen from one pad of the headphones. Now, I'd like a change. Within that category, what are the best headphones for me? I like the sound, build and closed back of the P5's.
quadpatch
860
The first thing that came to my head is the V-Moda M-80. It costs less than the P5 but I prefer the sound and the looks. If you don't like the idea of that also consider the Sennheiser HD25-1 II, Beyerdynamic DT1350... that's all I can think of for now. Do you like the small size and wear them outside much?
dalethorn
2,222
The VModa M80 would be the logical choice, having a similar smooth and wide-range sound as the P5. But the Beyer DT-1350 sounds way different - almost the opposite of the sound of either the P5 or M80.
