the best low price speaker cable
Hi
Please can anyone recommend the best low price speaker cable for a arcam alpha 8 amp and looking to get either wharfedale 9.1 or misson 751 speakers.
Look on ebay for Van Damme 2.5mm
It's around £2 a metre and as good as you need.
T
the record spot
Two things:-
1. The Mission 751s are the better speaker, even for their age (is this the original with the bass port to the front?)
2. Multistrand cable - think 322-strand as a minimum - is fine. Companies like Digitalis Direct will do you 10m for about £5.50 and it'll work a treat with the Missions. I used the same with Mission 752s and it was excellent.
moon
47
Hey Snivil, that's Expencive!
try 322 strand from the bay, 50p a meter. superb :shhh:
I guess, but it's a well made, professional reliable cable. And £12 for a 2x 3m pair is hardly pushing the boat out. I agree some of the other ones will probably work just as well, but you just never know with ebay.
Hi
Thanks for your help. Is it better to bi - wire the speakers if so is this easy. Also could anyone suggest the best low price DAB tuner for the set up. arcam alpha 8 amp and arcam cd player with hopefully the misson 751 speakers - do not mind second hand equipment.
Many Thanks
visionary
80
+1 :) value for money cable. Good quality as well.
or for quantity buy it on the drum :)
http://cpc.farnell.com/van-damme/268-502l/vandamme-hi-fi-spkr-cable-2-5-50m/dp/CB04675
field said:
Hi
Many Thanks
There is another thread on this somewhere. The majority (including me) think bi-wiring is a waste of time and offers no improvement so long as you aren't running on bell-wire!
