hello all, i have these speakers and need to replace the foam at the bottom of the bases,do any of you know where i can get this foam or can i use any foam.
I dont know for definite but i would reckon the foam is not hi fi specific and you could replace it with any foam of similar density. There are shops about that sell foam of varying density and will cut it to size for you.
I never heard the "2" but the "3" are pretty good for not a lot of money. You can use a pair of socks instead of form btw, just make sure you wash them first 🙂
