- Apr 22, 2009
- 79
- 0
- 0
MUSICRAFT Looking good :) [/quote said:I don't care for the wallpaper.
Aren't the speakers rather close to rear and side walls? Maybe you don't have an option.
ifor said:Hi ifor wallpaper going soon cables chased into trunking in wall new carpet + redecorate speakers are a little closer to walls but no option but so far no problems with boom/ bloom although not realy turned it up yet the r700 are on home dem to see if I can get away with it so far I am well pleased I am listening to Elto John Tumbleweed connectio:cheers:MUSICRAFT Looking good :) [/quote said:I don't care for the wallpaper.
I was listening to GBYBR just the other day. He used to be very, very good.ifor said:I am listening to Elto John Tumbleweed connectio:cheers:
ifor said:ifor ... Stop being so complementary you old softie. He is sure to move the walls out and chuck some paint on walls. Wallpaper is soooooo non hifi I recon specially in a darkened room.MUSICRAFT Looking good :) [/quote said:I don't care for the wallpaper.
Aren't the speakers rather close to rear and side walls? Maybe you don't have an option.![]()
Hi Cno I think the floor is suspendid its an old terrace house with floor boards and a high ceiling 8ft I have been running some bass heavy tracks at fairley high volume well above what I normaly listen at and I am well pleased no boom its still earley days as I am about to test with some rob zombie rush any bass heavy tracks you could suggest :cheers:CnoEvil said:Hi TM, that all looks very good....but you need to try some bass heavy tracks, with the volume up a bit, just to make sure they don't overpower the room. Is the floor a suspended wooden one?
Hi BenLaw I will be listening to some atc scm40s the weekend after next how are the atc at low volume the kefs are very good which is a bonus it means I can listen for longerBenLaw said:Nice TMKeep us updated as to how you get on.
