What I'm looking for is effectively any system wide audio streaming solution, that'll transfer audio content lossless from Android to any sort of receiver I can connect to my amp. Effectively like aptX Bluetooth streaming from my Samsung, except hardware / chipset independent and lossless at at least 48kHz (which means no crappy lossy compression applied anywhere in the audio chain).
My Samsung Note 10 Lite for instance supports aptX, but only at 44.1kHz.
This will only be possible though WiFi, but any sort of solution I've seen is completely proprietary like embedded streaming support in Quobuz, Spotify, etc. apps that at the end of the day your amp needs to support and doesn't give you any freedom to stream audio system wide (which should be the norm!).
I have a Chromecast with Google TV, and even though I've read it can output 48kHz perfectly fine it apparently is not possible to use the device for audio streaming?
There's some sort of guide by Google that explains how to do this using the Google Home app, but apparently this only works for Chromecast for Audio devices? (I got one with Google TV and there's no option to use the dongle as receiver in the Settings menu).
So, is this really only possible by limiting yourself to particular apps like Spotify or Qobuz, or does a system wide solution exist in any way for Android devices?
