System Upgrade Advice Please!
Not being massively knowledgeable on matters Hi-Fi, I thought I would ask for some views on what to spend some cash on to upgrade my current system. All opinions gratefully received!
Current System:
Amp: Rotel RA930-AX
CD: Rotel RCD930-AX
Tuner: Denon TU1800-DAB
Tape: Yamaha KX-390
Speakers: Kef Coda 7
Ipod Connect: Russ Andrews Ultra Plate Phonos
Speaker Cable: QED Silver Anniversary with QED Airloc terminations
Interconnects: Non branded
My main focus is on Amp and Speakers as most of the music listened to will come via my Iphone and I use the DAB radio a lot as well.
Looking to spend around £300-400 on each, either new or find an ebay bargain from the £600-£700 range.
You could look into the Creek Evo 2 amp from Shadow Audio at £499.
For source, what about buying a DAC like the Cambridge Audio (£230) or Musical Fidelity VDAC (£140)? Unfortunately your CDP doesn't have a digital out (according to the manual) so you'd have to find another unit to provide input to a DAC, perhaps a DVD player. A DAC would then let you connect other digital sources too, like a computer, etc.
Alternatively, you could hunt out a matching Creek Evo 2 CDP.
Thanks for the suggestions igglebert, excuse my ignorance but why do I need a DAC?
corrias
9
Also you should look in to spending a little bit of money in your interconnects, even £20 goes a long way and can bring out amazing sound from you existing components.
