Gerrardasnails:plastic penguin:Gerrardasnails:plastic penguin:Gerrardasnails:plastic penguin:
maxflinn:you've ruled out the dm 2/7s pp? did you get to hear a pair?
It breaks my heart to say I've knocked Dyns on the head. More truthfully, I need a speaker that is as flexible as possible in terms of positioning, hence ATC and Spendor (the latter probably SA-1). To make the Leema really sing I'll probably need the Focus or Contour, but they don't offer that variety. Shame, I'm limited by room topology, otherwise the Dyns would be a part of the short-list.
I have to say that I wasn't that impressed by the ATC 11s. If I were buying standmounts, I would definitely listen to the SA1s - they look lovely and after a few weeks with my Viennas, I would listen to the Haydn's.
The only snag about Viennas is there are very few outlets. I think the nearest is up in the Midlands which makes it, for me anyway, a little tricky in terms of shipping and possibly returns if they don't sound the biz.
I've decided floorstanders are a little too overpowering for our living room, so standmounters + a compact sub is the sensible solution.
Some Sevenoaks, Holborn being the nearest stock VA now.
Interesting. In terms of presentation, how do they differ from the RS6s?
I haven't listened to the standmounts but my Mozarts are on another level. They cost almost 4 times as much so not a great surprise. One thing that was instantly noticeable is that when I used to turn the volume up with my RS6s, the sound changed as it got really loud. With my Mozarts, the sound just gets louder. The soundstage is massive and the mids are smooth. Bass is big but very musical whereas I know now that the bass I had before was just big and fast - I now hear range with the bass. And, the RS6s as you know are very nicely made. The VAs look like a stunning piece of furniture.
Cheers, Gerrard, certainly worth investigating. BTW, are they rear or front ported?
