surround sound issues!
hi,
can anyone help?
i have moved house and i havnt been able to set my surround sound fro a while.
i have just set it up as im now settled in my house but the problem is no sound
system as follows:
pana 50'' plasma
denon avr.150 amp
elac 5.1 speaker set up
sky hd
optical cable from amp to sky
i had previously had this set up with virgin and it was fine, but it doesnt even work with my ps3, i have set the ps3 to optical nbut still no joy.
the speakers have been remotley set up and have calculated correctly and they still dont work.
my thouight is the settings on the amp?
help?
cheers
john
chudleighpaul
129
First and foremost can you get any sound out of the amp using the internal tuner?
Second does it have speaker selection controls on the front of the amp? If it does check you have selected the correct setting.
Third, and this may sound too obvious, is the muting control set to mute?
hi,
cheers for this,
1st no sound at all only when the speakers are calculating
not to sure about setting the internal tuner up?
2nd speaker settings correct
3rd not on mute
thanks again
professorhat
992
22
18,895
If you're not getting any sound during the speaker setup then something is fundamentally wrong. All I can suggest is to make sure all the cabling for the speakers is correct. If it is, I would have to assume there is a fault within the AV amp since it's extremely unlikely all the speakers have failed at the same time.
Do you have anything else you can test to drive the speakers, just to make sure neither they nor the cables are at fault?
chudleighpaul
129
PH, he is getting sound during auto setup, but nothing else.
The Sky box should have analogue stereo outs. Try connecting these to a stereo pair on the amp and see if you get any sound.
Alternatively I believe panasonic tvs have analogue stereo outs, Try these.
professorhat
992
22
18,895
chudleighpaul:PH, he is getting sound during auto setup, but nothing else.
Quite right, sorry. Seems I can't read today
