Suitable speaker cable for 3020 speakers
ID.
207
brucefan64 said:
What speaker cable would people recomend to use with these speakers .
anything long enough to reach from the amp to the speakers.
Or, alternatively, as I think the speakers are quite warm get some Nordost to help bring out extra detail and add speed to the sound.
slice
6
.....is the usual decent quality reply to this question, 2.5mm cross section is enough for most run lengths. You can get it on amazon and many other places. You can spend a lot more, this is a typical answer from those of us who believe that sufficient copper is the determining issue. If you want to explore the issue of cross section v cable length, search speaker wire in wikipedia.
