Subwoofer placement
camdxr
50
Hello Everyone
More equipment placement questions. After relocating my AV gear to an in wall set up I'll be left with a 50cm x 50cm x 50cm "hole" in my cabinet. The hole goes down to the floor and is covered above by a 2cm thick piece of granite (extends either side over the cabinets).
My RSW 12 subwoofer will fit easily and would look good, would the sound suffer being inside this "box"?
Thanks.
fayeanddavid
191
camdxr said:
Hello Everyone
Thanks.
Would have thought so, as you are placing the sub in a box and as such will create all sorts boominess and "flob" ( for want of a better word), corners are normally very bad so a 3 sided "corner" would be worse.
I have my sub in a corner but 25cms clear on the two sides and sounds excellent.
Andy Clough
776
No, I wouldn't recommend it as the best place to put your sub. It will sound better out in free space.
