- Aug 10, 2019
- 2,556
- 5
- 0
Recently purchased the PV1 to replace an older mission sub in my 2 channel setup. The current subwoofer connection is via the B&W supplied ARJ45 line level inputs which are fed by my 2 channel amp's speaker outputs. This I understand to be the recommended connection per B&W instructions.
I am experiencing subwoofer hum (not a soft humm but quite a noticeable one) when the sub is turned on. After doing some reseach I believe this is due to a ground loop issue as the PV1 does not have an earth plug on the power cable. To verify that this is indeed a ground loop issue when I remove the connection from the sub to the amp and turn the sub on the hum completely disappears.
The practical solution to this would be to earth the subwoofer to the grounding terminal on my amp so that the sub is not fighting for the ground. However the B&W manual indicates that the sub does not need to be and should not be grounded. I am lost as to what to do but am pretty sure this is the only way to remove the hum. (My previous sub had an earth plug on the power cable and never hummed). Should I ground the sub and disregard B&W's instructions or is there another way around this? Any advice or experience with a similar problem will be greatly appreciated.
PS: I cannot use a grounded 3 pin power cable on the PV1 as the sub only has a 2 pin power cable socket.
PPS: The sub and amp's power cables are all running out of the same wall socket in the wall and I have tried inverting the sub plug but the humm is still there.
