I've got so many questions about subs but there doesn't seem to be many answers when it comes to using them for hi-fi.
Firstly what is the best way to wire a sub up to a stereo amp (Marantz PM4400?) Is best to wire it up like a normal speaker or should I use the tape loops?
Secondly if I get an active sub is its amplification completely serperate to my amp? So if I got a 100w sub would it still go up to 100w even though my amp is only 30w? If the sub has speaker outputs as well as inputs does this mean it will give my speakers more power?
Finally what is a good sub to go for? My buget will probably max out at around £150. The sub will need to be fast, give good quality room shaking bass and not struggle with loud volumes. It will need to be able to cope with music such as Pendulum, The Prodigy and Muse. So far I've looked at the BK Minotaur and the Mordaunt 309i. While I would like the 309i it's unlikely I'll be able to afford it so is the Minotaur any good? Is there any other subs worth a look bearing in mind my room is 2m by 5m.
