Don’t go for a cheap sub as it will only have ad adverse effect on your sound, I’d rather have a bass light tight sound than have an out of sync bloated fart accompanying your speakers. Many subs under the £300 mark tent to fall in to this category, thankfully you’re just about the right side to find something that will compliment your system.
At think at this price point you need not look further than the subs from BK as they cannot be beaten on price and their specs are superior to similarly priced subs in terms of cabinet volume, driver size and power. They also built solid well braced cabinets and use quality drivers. They are UK made, have a good following and come in a wide range of finishes.
The XLS200 is a touch over budget in the standard finishes and I’d say would be worth pushing your budget for, if not go for the smaller Gemini. I have the XXLS400 and it is excellent for the money.
http://www.bkelec.com/HiFi/Sub_Woofers/XLS200-DF.htm
