Subwoofer for 2.1 one system
Hi, i am currently looking for a sub to use for a 2.1 system in conjustion with monitor audio br1's and denon dm37. I only have about £100 to spend so i am definiatly looking at the second hand market. What would you recommend at getting that would be a few years old so i could get it on the cheap.
Thnaks for the quick reply! looks ideal but with 3 hours left i think it will go for quite a bit! is that sub any good anyway
8009514
72
I see you got it then, well done. Just about the budget you had to spend as well, with postage included. Would like to hear how you get on with it as I have exactly the same system as you, and am also thinking about a sub.
