Sub df vs ff is there a difference
Been lookin at bk subs i see monliths come in both df and ff aan the xl300 is ff. Is there a difference performance wise?? it might be worth sayin a df might be more suited to my set up.
Placement of the sub is quite important, and probably more important than the type of sub you get. But to answer your specific question, I think it depends on your room. If you have a suspended floor, a downward firing sub will be felt more as it's firing directly onto the floor, instead of firing into the room. If your floor is concrete, the downward firing won't really have this benefit. Firing your sub into a wall or into a corner can improve it's output level, having the benefit of not having to drive it as hard. This is only recommended if you have solid walls.
Thanks well i have laminate flooring on top of a concrete floor so an the only place i can put a sub is at the side of a couch so i can not directly see it in front of me
can any1 advise
