Jame5 said:Can I ask why you have no interest in streaming from your PC? If you connect your PC via a DAC to your amp then you can use your phone as a remote which will give you almost the same user experience as streaming from the phone, but with access to all of your music.
If you go down the airport express route, consider whether the internal DAC will do the rest of your set up justice.
The PC is wired into the same network as the Airport Express is. If i want to go for better sound and use a separate DAC presumable i would put it between the AE and the amp and have a different output coming from the AE. All the music i would want it on my iphone and it would seem to be easier to stream from there. I'm not an expert in computing and electronics and would like to keep things as simple as possible.professorhat said:For the money, the Airport Express sounds pretty good (in my opinion). You can obviously improve it with an external DAC later on if you choose to.
If you're using iTunes on your PC and it's connected to your wireless network, you'll also be able to stream music from it to your amp using the Airport Express. You can control this from your iPhone using the Remote app. Or you can just stream direct from your iPhone - choice is yours.
EDIT - Sorry, just re-read your post and saw your PC didn't have a wireless connection. However, as long as the PC is connected to the same network as the Airport Express (although obviously via a wired connection), you could stream from your PC this way.
drummerman said:Or you can try one of these
http://www.logitech.com/en-gb/speakers-audio/home-pc-speakers/wireless-speaker-adapter
I got one sitting in front of me but haven't tried it yet.
I'll post in a day or two.
regards
shep1968 said:If i want to go for better sound and use a separate DAC presumable i would put it between the AE and the amp and have a different output coming from the AE.
shep1968 said:drummerman said:Or you can try one of these
regards
This would also be an interesting option but would the iphone output to it? I* seem to remember it not being able to do the same kind of file sharing as opther devices.
professorhat said:shep1968 said:If i want to go for better sound and use a separate DAC presumable i would put it between the AE and the amp and have a different output coming from the AE.
Yes - the output on the AE doubles as both a 3.5mm analogue output and a Mini TOSlink digital optical output. To use it with a DAC, you'd just need one of these connected to a standard optical cable. This plugs into the AE and the standard optical connections plugs into the DAC. The DAC then connects into your amp via standard RCA phono leads.
Did you try this drummer? If so what did it sould like?drummerman said:Or you can try one of these
regards
drummerman said:I guess it makes sense if you are an apple user.
Personally, I think the brand is the spawn of the devil or some secret government mind control device and sends out subliminal messaging, such as ... buy the latest me ... now ... even if you only had the previous me for a month. Cue even if its for days and you freeze your gonads off whilst doing so. It also tends to make you post the same thing three times ... and has been known to make grown up men behave child like, unusually stubborn and irrational. I'm not talking about Ashley by the way.
regards
Thanks for all your help on this. I have my AE and am streaming not only from my iphone but also from itunes on my wired computer, something they told me couldnt be done at the apple shop!! All i need to do now is to reburn all my cd's in lossless onto an external drive for better sound quality. Not sure how i do all i want to but suspect that is for a different forum.shep1968 said:professorhat said:shep1968 said:If i want to go for better sound and use a separate DAC presumable i would put it between the AE and the amp and have a different output coming from the AE.
My amp doesnt seem to have an internal DAC and also no optical connection. Suspect that i might try the AE and go for an external DAC if the sound quality isnt as good as i like. I burn all my cds as 256 kbps and have no downloads from itunes. Is the sound quality going to be significantly down on what i get from a cd or what i get if i simply plug my iphone into the amp itself?
