Streaming music from itunes to ipod touch
mattjax05
230
I understand you can do this with airfoil on the pc and the airfoil speakers app for the ipod but is there another way without airfoil as it's £25 and I would just stream itunes.
It's not great, but it will do it. I think it helps if you don't share your entire Library of songs as this seems to take an age to synchronise.
EDIT - haven't used it in ages though and it looks like it's changed quite a bit now I look at it so maybe it's not so bad now!
Can't you get it on expenses?
JohnDuncan:First impressions - sound quality not as good as Spotify.
What about compared to the airfoil speakers app?
Tricky. I think the underlying quality of airfoil speakers might be better, but it has much more trouble streaming (perhaps in both cases because I'm playing lossless), so you get a poor quality connection and thence subjectively worse (or at least variable) sound quality. I need to experiment...
