davedotco said:
Put simply the CD player reads the disc once, in real time, and errors may occur, premium ripping software will read the disc a number of times to get all the data correctly then perform a 'check sum' calculation to show that it is correct. Play both data streams through the same dac and they should sound the same, unless the CD is difficult to read, in which case the RIP may sound better.
I like it how the FIRST sentence in the FIRST answer is already a technically completely wrong.
CD's had and have always today a mistake corrections that is absolutely flawless. Some first designs needed some improvement but the technology was rapidely mastered and never changed since them. CD was and are extracted with an accuracy of 100%. I don't like to make crossgender examples (because informatic is informatic) but If it wheren't so, you couldn't use any computer CD at all to transport a programm, because the content would never be extracted well. And when the sound wheren't extracted correctly, you wheren't able to listen to your songs without some very audible holes in it (like the old discmans that jumped sometimes due to massive rattling).
They are real advantages about streamdacwhatever.
1) The mecanic is one of the downpoint of cd players, that could break during the year and, for some unserious brands, become difficult to replace (around 80% of the builders today are unserious and will not offer repair of the transport after a 5 years time... the best reaches 15 to 20 years of parts warranty).
2) The fact that you can quickly access what you like with more speed is another strong point too.
3) And you will be able to play your original stuff on some higher level (even if I aleredy think that the CD 44/16 is more than enough for enjoying troublefree reproduction).
But be aware that, everytime you are putting on an informatic device, it will try to spy out the content of your private life. Sometimes a little bit, sometime massively. For me a major downpoint in all this technology. Although, you have no insurance that CD will stay integrated to your PC's during a long period of years. If I search the floppy disc on my computer now, I will not find it, and it's the same problem with cd.
