Hello,
Having some trouble with my AV amp front left channel at the moment and have used the pre-outs to put the front two channels through my stereo amp. It sounds fine. Depending on price of fix might even use this configuration going forward.
However, the AV amp is 100W per channel, which is average for an av amp, and the stereo amp only 30. I'm thinking if I turned the AV amp right up it would be asking the stereo amp to output 100W per channel, which it can't do, but I never crank it anywhere near the top, and it's seemed OK so far.
Looking at it as a possible longer term solution, to play it safe power-wise and give my av amp full range, I'd need a 100w per channel stereo amp. Stereo amps with 100w per channel seem to cost at least £1000, with those up to about £600 - 700 being 30 - 40w. But I'm sure not everyone who uses such a setup pays that much for their stereo amp?
So I'm wondering am I understanding the power needs of a stereo amp in this configuration wrongly? Any advice would be much appreciated.
