- Aug 10, 2019
- 2,556
- 5
- 0
OK – so bash me over the head with a mallet for asking a simple Q but:-
My non-technical non-geeky understanding of types of speakers is that there are two main types:
Floor-standing and Stand-mounters (Yes, I guess there are others such as recessed, flat, underwater and goodness knows what other gimmicky things).
But in the esoteric HI-FI world I guess the FS and SM are the main choices.
It would appear to my limited Hi-Fi appreciation that position is critical for ANY type of speaker.
So, with regard to Stand-Mounters, “WHAT” one places these type of speakers on is critical.
Hence my question is “what characteristics and qualities should a good stand have?” ie What is a stand supposed to do musically?
Many thanks in advance
Serenity
"If you hear anything that I say, then I invite you to take it and use it as your own. If you resonate with it because that's what we will make it your own. And if you don't, then throw it away. Don't try to wear a shoe that pinches." Gary Zukav
Serenity
