- Aug 10, 2019
- 2,556
- 4
- 0
I've been toying with getting a music streamer to compliment by hifi (per footer :read: ). I only need a pure streamer, no DAC or amplifer required. My CD collection is ripped to WMA lossless (to aid support with iTunes) but assume I can easily convert this to FLAC using dbpoweramp. I had thought about using my Sony BDP s470 player but (a) it doesn't support WMA lossless and (b) requires the TV to be on.
My PC is currently connected to the Wadia using a [digital] coax cable, and it sounds fine albeit a bit flat, however I question whether the PC is somehow pre-processing the signal, and of course the PC as to be on to play music, and it is not exactly silent. And I can't move the PC to another room.
I've looked at both the Squeezebox Touch and Sonos ZP90, both seem pretty similar but have slight differences in functionality (Note: I have an Android phone):
Sonos ZP90: Can be used with my phone as a remote, cannot use with USB disk directly, has to be either NAS (more £££) or connect to PC (noise). Has great flexibility to expand wirelessly to other rooms should the need arise.
Squeezebox: Has nice display with touchscreen, and supplied remote. Can use with USB disk directly (have a 750GB one) so not reliant on PC being on.
I'm veering towards the SB, which I would use with my existing USB drive having converted the WMA files to FLAC. Any other thoughts or views on alternative products welcome...and would love to know if there is any difference in SQ using digital out between these two.
