Sqeezebox, which one
Sospri
28
Hello,
I stream FLAC file from my laptop to my Squeezebox classic to my Supernait digitally, and was wondering whether the duet or touch would be an improvment sonically over the classic and would be worth changing ?
Or any other sugestions would be welcome......
Thanks in advance guys....
Sospri said:
Hello,
They will sound identical unless you're using the analogue out, although the touch is 24/96 compatible if you like that idea.
Thanks for that, not worth changing then.
I might just aquire the funds and go for the uniiqote at a later date.............
