SteveR750 said:Is it worth the upgrade from spotify open for the sonic improvement (if any). I know about the ability to play offline / mobile etc.
SteveR750 said:Nah, that can't work, gotta try the real thing innit.
paradiziac said:SteveR750 said:Nah, that can't work, gotta try the real thing innit.
Aye, trying the real thing is probably your best bet. Life is short!
Though personally, being slightly obsessive and already having installed this stuff on my PC, I find it interesting to ABX files with Foobar. Because I was able to convince myself that Spotify premium seemed "slightly" better than the standard quality, but doing a proper ABX test in Foobar I was not able to tell the difference.
OK, ABX tests are not the be-all-and-end-all, but that said, if you can't ABX it, it's probably not worth worrying about!
SteveR750 said:Fascinating stuff para, but when do you actually get to listen to an album?![]()
paradiziac said:SteveR750 said:Fascinating stuff para, but when do you actually get to listen to an album?![]()
I'm saving up for a turntable![]()
Lee H said:Altough the app has a bug which reverts it to ordinary HQ every time you exit it
HDNumpty said:Not on my iPhone it doesn't Lee. What iPhone are you using?
