- Aug 10, 2019
- 2,556
- 3
- 0
Hi all, I don't post often but I read the forums most days and I hope one or two of you may be able to help with my query. I would greatly appreciate your suggestions for stand mounts or small floorstanders for use with the Unitiqute. I heard the qute at the Bristol show with some Guru QM10 speakers and was blown away. However, my budget doesn't stretch to the £1800 Gurus
My budget is up to £600 for the speakers. I can get the Qute for about £1100 ex dem. Aside from sound quality I am keen on the Qute as it has enough digital inputs for my Apple TV (streaming Spotify over Airplay via iPad), Blu-ray and Sky Box, as well as an analogue input for my Wii. I also like the fact it is all in one. Are there any other products similar in spec to the Qute that would give me 3 digital inputs and 1 analogue with a remote control which I might be interested in? I listen almost exclusively to dance/trance/electronica. Given the Qute's 30wpc, I anticipate that speakers with a sensitivity of around 88db+ would be wise? Regards, lordgrace
