Speakers to match Fatman iTube Valve Dock
Hi Folks,
New to the forum (HI! [:D])
For Christmas I got the Fatman iTube Valve Dock and i just need to match it up with a pair of speakers. Have a budget of about £300. Was going to go for Monitor Audio BX2's or a pair of the Mission MX1's will there be a big difference between the two as there is only a £100 price difference.
Shaun
anyone?
For my main system i have Cambridge Audio Amp and CD Player paired with BR'2s. Will my Fatman sound better than this?
gregory
45
Why not try the BR'2s on the end of it and see how it sounds, you may be suprised how good it sounds.
If i ran it with my Br2's i'd then need to replace them in my other room...
Thinking of Q Acoustic 2020's what is everyones thoughts on these are the right spec to be matched with Itube?
The Br2 are an excellent match for the Fatman, just get two pairs!
gregory
45
yes go and buy them they will sound fantastic better than you can ever imagine they will match up lovely you will not find anything better i cant think of anything else as good why didnt i think of them before you must be a genius
Still not sure I understand your comment, care to elabourate?
sorry. a bit slow today. Advice...falling on deaf ears and all.
So I should just buy a second pair of BR2's. Bit bigger (dimension wise) than what i was after but have noticed they have came down a lot in price recently.
Is that not a bit boring though having the same speakers in two different rooms?
and in reply to gregory i already have tried it with my Br2's sounded okay/good but seeing as i was going to be getting a new pair of speakers i wondered if they could be bettered!
