- Aug 10, 2019
- 2,556
- 4
- 0
Hi gurus,
Need some advice to shortlist speakers for auditioning. Based on reviews I will go with Rega Apollo source with Roksan Kandl L amp. I have a mid-size room 7m by 4m but since I live in a flat I prefer to listen at low volume ( maybe 2 or 3 in scale of 10 ) and occasionally louder. The reviewer said in the magazine that ATC SCM11 are the best suited but they sound best when played loud. So I am not sure if I should audition these. Appreciate if you can help me select some decent speakers that plays good at low volume and are suited to above source-amp combination.
Thanks a lot.
Cheers,
Neeraj from Germany
Thanks a lot.
Cheers,
Neeraj from Germany
