power said:
I have a question about speakers specs. I fully understand what the frequency response means but I dont really understand the meaning of the frequency range. Which between the frequency response and range is more useful in setting the low pass filter. I have B&W CM8 and their specs are as follows: Frequency response 69Hz - 22kHz ±3dB on reference axis Frequency range -6dB at 43Hz and 50kHz Can someone explain to me the meaning and implication of this specs?
My understanding as to the significance of the two different ranges is as follows:
The frequency response figures (+/-3db) signifies the accurate range, beyond which any frequencies produced will be audibly quieter than those within the range, ie in your example frequencies below 69Hz or above 22kHz will be significantly quieter and therefore not accurate to the original fecording, compared to those within the 69Hz - 22kHz range. There may also be more distortion to frequencies produced outside of this quoted range, due to the drivers reaching the limits of their frequency capabilities.
Gregvet's explanation sounds very clear to me.Thanks a lot to explaining it like that. . Like i said in my 1st thread that my speakers specs frequency response is 69Hz-22kHz at +-3db and frequency range is 43Hz and 50kHz at -6d. I realise that Most people in the forums seems to feel 80Hz is the gold standard for setting the receiver's low pass filter. I tried setting my low pass filter for the mains at 80Hz but i find the sub to be too audible. I found 60Hz to be the best sounding. The question then is do I loose out on some frequencies considering my speakers specs and how I set the low pass filter on my receiver?
The frequency range signifies the absolute range of frequencies produced by the speaker, audible to any significant extent. Once they get more than 6dB quieter than the other frequencies, there is considered to be an insufficient response. So in your example frequencies below 43Hz or above 50kHz are not produced at all to any significant degree.
The above may not be textbook accurate, but explains in laymans terms my understanding (being a layman myself
