Speakers for CA AZur 650 combo
hortensio
22
Which (budget) speakers are best for CA Azur 650 combo?
@ MS Avant 608
@MS Aviano 6
@Epos 12.2(i)
@Quad 12L
any other sugestions???
Thanks....
hortensio
22
@ MS Avant 608
@MS Aviano 6
@Epos 12.2(i)
@Quad 12L
Thanks....
oh, I mean MS Avant 908....
Blackdawn
88
It would be good to first decide whether you like or want floorstanders or bookshelf speakers. They are very different in looks and usually sound. Your list is 50/50 split. Which would you like? You may need to consider room placement, space available and factor in price of stands if you go the standmount route.
damonster
30
i have some kef 1q5se speakers i got from richer sounds 7 months ago. x demo were £400 i got them for £ 280 because the tweeters are bent in ( but still sound amazing) and a few marks on the cases .I will be listing them on ebay in the next week or so .These have an amazing sound for the size of these floorstanders.would be good with your setup.
CnoEvil
556
11
IMO. The IQ5 are good little floorstanders, but could sound a bit on the bright side with the CA amp. As PP says, go and try a few combinations, as at the end of the day, the only opinion that matters is yours.
Cno
Its been nearly 4 months I've been listening to CA Azur 650 combo with Aviano2 speakers, but somehow I'm not satisfied with the sound. I'm finding the treble a bit sharper and the bass lacking the punch. A bit higher volume level, say at 9 o'clock, the sound creates fatigue. I'm simply clueless as individually these gears have received good reviews. Please suggest, which component I need to upgrade/change? :?
