Hi SC, I have not bought the speakers yet.
In the end, I went for the CDQ.
My advise is, skip the first batch of CDQ as it did not come with the 12V trigger for power amps.
I knew about this when I purchase my CDQ but no regrets.
Skip the 8200A and get the 8200MB or 8200P/M when available.
Or choose any power amp you desire (after auditioning of course).
The pre-amp section of the CDQ is excellent. I would advise to skip any int amp or pre amp use and straight away use a power amp.
Best to use the XLR option if available on the power amp you choose.
The 8200MB for example, comes with XLR input.
As it does not have the on/off switch, therefore, the 12V trigger on the CDQ is quite important imo.
I decided to go for the new MA GX speaker.
Most likely the GX100 if funds allow. Otherwise the GX50.
Have a little write up here
http://community.whathifi.com/forums/p/554207/555443.aspx#555443 .
But they should only arrive in April.
sedish chef:
Have you got your speakers? If so, what was your choice?
I', looking to get an Audiolab CDQ but with a pair of headphones. I can then add more once I have the cash. I was also looking at the Audiolab 8200A if I were to go for the straight Cd player. Would the CDQ and A be compatinle?
It'd be interesting to hear what you've got to say about 'em
