Hi, after my NAD amp packed up, I have bought a Marants PM 6002. The main speakers, some very old wall mounted Pioneer speakers (8ohms) 40x23x25, are wall mounted and have to be quite close to the wall. The lounge it's in is 17 feet by 10. I connected the Marants to a Sony mini hifi system with 6 ohms speakers. It used to be fine with my ancient NAD, but with this the result is quite bad, even if I keep the bass to the lowest lever it's still too strong and over shadows the other instruments and voice in most tracks.
Can you suggest a solution? Different speakers? I was thinking of the Wharfdale Diamond 9.1, the Tannoy Mercury F1 custom or the Monitor Audipo Bronze BR2. Would they help, conidering that the speakers will have to be wall mounted close to the wall. Or is it the mini hifi giving the problem? Is there a compatible one with the Maranz or I have to get separate components?
Thank you very much for any advice.
