i always get confused with speakers - whats easier for an amp to drive a speaker at 87db at 8 ohms or a speaker at 91.5db at 8 ohms?
Sensitivity ratings are given in decibels per watt at one meter, or db/Wm. So, with an input of one watt (usually white noise), a speaker with a sensitivity of 90 db/Wm will produce 90 decibels of sound at a distance of one meter. A sensitivity of 90 is considered average, with ratings of 87 and below considered low sensitivity and above 93 considered high sensitivity. To increase the volume by 3 db, you must double the power. So, using the example above, to make 93 db you would need two watts, and to make 96 decibels, four watts.
