Speaker plug Converter - banana plug to z plug?
I am hoping that somebody can help me. I have chord speaker cable fitted with Chord banana plugs, which I am having difficulty connecting to both my amp and speakers.
Is there a "z plug" converter out there on the market that I can possibly buy and fit my chord plugs directly into, as I do not fancy having my to reterminate all my speaker cables, especially as it has been professionally fitted with the chord banana plugs.
Any help/advice would be very much appreciated.
audioaffair
100
Chord should be able to offer something to help you through your dealer - worst case scenario they could be reterminated - best case they could make something based on the same Chord cable you're using.
