More information required. What is a medium sized room in metres length and width?Suitable/best Speaker match using Audiolab 6000A & Audiolab 6000CDT
in med sized room. Any positive help appreciated. Price up to £1,000.
Do you have stands or will you have to budget them into your £1000?
[/QUO I have stands.
Thank you.Wharfedale Evo 4.2? Three way standmount with AMT tweeter and soft dome midrange driver for £600. Leaves spare change for some very good stands…. Came top of a speaker shoot out on Pursuit Perfect System. 🙂
I preferred them to the KEF LS50s which I had 👍
Recommended speaker cable for Wharfedale EVO 4:2 Speakers please?
thanks. If you got them from the same dealer one would have hoped they might have thrown in some speaker cable.Brand new, no speaker cable.
If you want a recommendation….not a discussion, I would suggest cable by Chord or Atlas. Chord RumourX or Atlas Hyper would be appropriate for your new kit. Good luck,👍Recommended speaker cable for Wharfedale EVO 4:2 Speakers please?
Thank you.If you want a recommendation….not a discussion, I would suggest cable by Chord or Atlas. Chord RumourX or Atlas Hyper would be appropriate for your new kit. Good luck,👍
