- Aug 10, 2019
- 2,556
- 5
- 0
Because of our room layout, it’s not possible for me to have the amplifier and the speakers close to each other. So I am now wondering about the correct gauge of wire that I should use in relation to the cable length. The speakers are the Mission 782, which, on the id plate states that they are 8 ohms, but in the user manual it says 6. Putting a test meter across the terminal reads 6.25ohm, so I’m working on 6 ohms.
The distance at the furthers point between the amp and speakers is currently about 8 meters, and going from the chart at http://en.wikipedia.org/wiki/American_wire_gauge, it indicates that I should be using16 AWG wire.
As this is not something that I have ever looked into before, correct me if I’m wrong, and excuse my ignorance, but I’m assuming that the 16 gauge relates to the thickness of each individual strand making up the cable. That being the case, how do I determine how many strands of 16 gauge wire would I need? I’m guessing that this has something to do with the amplifier wattage?
As I have a few options in the amplification area, this could range from between 60 watts per channel to 180 watts per channel, in which case, I’m supposing that I need to work off the 60 figure.
As I said, I don’t really know so would appreciate your advice on this.
Thank you.
Thank you.
