speaker cable
pete.g
33
Hi all
I currently use QED micro cable between my Denon 2310 and all speakers. I have heard people say the micro cable is fine for surrounds but am i losing out on sound quality by using this entry level cable on the B+W 684 front speakers.
If anyone thinks i should upgrade, what would you recommend - i was thinking of the QED silver anniversary XT cable
cheers
I got the QED silver for my front two, but forgot to buy for my centre, so was going to buy 1m for the centre, then wanted to listen to the sound from 1.99 p/m cable and 6.00 p/m and I could not hear a difference.
I even put it on one of the speakers and compaired and could not hear anything different.
Yes I only have diamond 9.1's, but I thought it was not worth it even for an extra 6.00
