Speaker cable question
What speaker cable would you recommend to partner a YamahaDSP-AX757SE AV Amp and Q-Acoustics 1010i with sources being a Panasonic BD55 and Cambridge Azur 640C V2????
I use QED micro for rears on my Q Acoustics package.
I did have the QED Silver Anniversairy at the front and centre, but found that using QED Profile 4x4, but as single cables (it's a biwiring cable) made a massive difference. It became a much more clearer and detailed sound.
Since upgrading my fronts to the 1030i (as mentioned in your other thread), I have now bi amped the fronts using the same QED Profile 4x4. This is all using the Onkyo 606 amp.
As for your system (QED Profile 4x4 is not made anymore, but can be found on ebay), I would suggest trying the QED Anniversairy XT for the fronts and centre .
Hope that helps....
I currently use QED SA on my fronts/centre and Ixos 233 flat on my rears but I've recently ordered this (2.5mm) for when I rewire the lot in a week or so. As long as there is plenty of copper, you'll be fine.
Pistol Pete1:
Hope that helps....
Thanks - btw, would love the 1030's but see my other thread, room layout rules out floorstanders
I bi amp/bi wire my fronts with Kimber 4TC and QED SA XT.
Price wise I think the SA XT takes some beating, and would Bi amp/bi wire with them on your Onkyo.
