speaker advice for Cyrus 6vs2 and smallish room
knacker
64
What speakers would work well in a room approx 2.5m x 4m ie long and thin and the speakers have to be near to a wall and will be on isolation platforms on a desk- no way to avoid it I'm afraid
Currently have a pair of MS902i but they are left over from a budget system
What's your budget?
I'd be thiking along the lines of Dali Ikon 2 or perhaps some secondhand Spendor S3 or S3e.
jules.
knacker
64
anyone else- budget around £200-500 ish
T
the record spot
If you can get them on a deal either Quadral Pico or Leema Xero's assuming the latter are a good fit. Both RRP'd at £650. Consider also AVI Neutron IV or V. All are well worth shortlisting.
