Spacers on Rega P3 for new cartridge
T
the record spot
I've bought an Audio-Technica AT-440MLa to fit to my Rega P3 turntable. The AT sits deep on the cartridge, much more so than rega branded cartridges. I've heard you can buy spacers to fit to the arm, thus raising it and making the VTA that much easier to maintain. However, I need to know where I can get one, what size I need and how it should fit on to the P3. All advice gratefully received!!
John Duncan
2,033
27
19,720
A Rega dealer will sell you a set of three (I think) different-thickness spacers for about 7 quid (I think) which you can mix and match to get the right height. Alternatively, there are some after-market ones which are infinitely adjustable from companies such as Origin Live, Michell and Incognito starting at 25.
T
the record spot
Excellent - thanks for the suggestions John; I'll follow up with the Rega dealers first I think.
