sound quality
Hi ive just purchased a Rega Apollo cd player to go with my Roksan amp and Monitor Audio BR5 speakers,using Audioquest Ruby interconnect and Qed qudos speaker cable. Trouble is it sounds a bit harsh on vocals,everything else fine.Is there anything i could to eliminate this.
hifial:Hi ive just purchased a Rega Apollo cd player to go with my Roksan amp and Monitor Audio BR5 speakers,using Audioquest Ruby interconnect and Qed qudos speaker cable. Trouble is it sounds a bit harsh on vocals,everything else fine.Is there anything i could to eliminate this.
Hifial - yes, there is, wait - just give it some time - a couple of weeks in fact. Then see if you dislike it.
What Graham say's is true, so don't worry it's not a placebo effect Once run in you will have a smile from ear to ear.
It's partly running in, and partly your ear adjusting to the new sound, I think.
What was your previous player? It could be the Apollo is that much better at resolving detail, so now you're hearing clearly what was veiled before.
My old cd player was a Technics had it for about 15 years.Should i leave the interconnect and speaker cable.
hifial:My old cd player was a Technics had it for about 15 years.Should i leave the interconnect and speaker cable.
yep-for now. As others have said, let your cdp run in propely, then i would think about upgrading to chord carnival silverscreen or the cobra mk3...
