- Apr 10, 2008
- 189
- 0
- 0
I am after a cheap accurate spl meter so I can set up my Sony S760 properly, would one of these do the trick ? They also have some "B grade" ones for £20, although P&P isn't included. I did have a quick look on a well known search engine and there seem to be identical versions at other stores for upto £70. If the one I linked to is any good I can go and buy it from my local Maplins, brand new one.
Do you need to set up the settings using C weighting on the slow response at 75db volume on the amp? Seems to ring a bell but I am not sure if I am correct. I take it you first set up the amps volume level to 75db and then go into the players settings and tweak all the channels to match?
