Sony2400es + Kef 3005se Settings help
Supernova 22
7
I need some advise on what should be the best crossover frequency settings to get the most out of my speakers, the amp is set at 120hz. I have all speakers set to small.
Should i change the frequency higher or lower separately for the centre and the surrounds ?
How will i get more bass from my subwoofer ?
Can you adjust the crossover frequency for the sub via the amp ? (i cant seem to find that option in the GUI)
Any help will be much appreciated !
Pistol Pete1
248
I have my 3001se rears at 100Hz and small, but I don't have them overly loud....
If your volume is loud, your 120Hz would be good, and I suggest the crossovers to be the same throughout each speaker......
Pistol Pete1
248
More bass from sub....adjust the speaker levels on the amp.......
You can adjust xover freq of sub on the amp......and I suggest it's used over the setting on the back of the sub.....
