Sony WH-100XM3 to amplifier?
Just using them to listen to - Mark Knopler - Sailing to Philadelpha. They sound incredable. Thanks for your help. I'll look into buying the Arcam rBlink.
And thanks Simonali.
Just Got this from Arcam
'Good afternoon
Thank you for your email. We do not make any bluetooth transmitters. If you use wireless headphones, then you will be using the DAC and amplifier built into the headphones, rather than anything that we have manufactured. If you want to listen to the CDS50 using the headphones, I would suggest a reputable Optical or SPDIF to bluetooth transmitter, although as we do not manufacture such products I cannot recommend any specific one.'
Anyone got any recommendations?
Thanks. I bought a TaoTronics adaptor (2020 version), and I'll install it in a couple of days time. Then I'll let you know how it is.
Thanks for you help bigboss.
Reactions: bigboss
I've been following TaoTronics instructions, and they are now saying my Sony headphones must be faulty. They cannot accept that there may be a problem with there device. So I'm sending it back to Amazon.
I'll have to think again about how to connect my Sony headphones.
