Hello,
Got my STR-DA2400ES yesterday and I've been trying to put it all together. The landscape is the following:
- STR-DA2400ES
- BDP-S550 connected via HDMI with a QED QUNEX HDMI-P cable on BD
- Playstation 3 connected via HDMI with a QED QUNEX HDMI-P cable on Video 1
- Sagem freeview tuner connected via AV cable to SAT
- Bush TV (I know...is next in line to upgrade) supports 1080i and is connected to 2400ES via a QED HDMI/DVI adapter
I can see the 2400ES menus and the TV is set in 1920 x 1080 (but does not support 1080p). 2400ES is setup with output resolution 1080i. The sound setup for 2400ES was without problem, all speakers working fine.
I can watch TV and 2400 is upscaling to TV. I get stereo sound and the receiver shows Analog in the display.
But, when I watch BD or PS3, the image is good (1080i in both cases) but I have no sound at all. The BDP-S550 is set to output priority on HDMI and the Audio HDMI is on Auto with BD Audio Settings to Direct. Both the DB player and the receiver show HDMI in their displays, but there is nothing else in the display (encoding information, speakers indication, etc.).
If I link the BD player with a digital coax (DVD coax) and I assign it to BD input and switch the priority to Coax, I can get the sound OK (I've tried with various DVDs using DD and DTS). But I don't understand why I don't get sound through the HDMI.
Another interesting thing is that when I setup the sound from PS3 and I put the output on HDMI and then Auto, the PS3 reports the error "This HDMI device cannot be used for audio output".
Does anyone have any idea what might be wrong?
Thanks,
Alex.
- STR-DA2400ES
Thanks,
Alex.
