[quote user="Andrew Everard"]
Sounds more like a problem in the EPG data being sent to the recorder. Worth a check with your retailer or Sony to see whether this is a known problem - they're usually solved with a download over the air, so if it is a problem there may be a fix on the way.
If not - and as you can see no-one else seems to be reporting the problem yet - it might be worth returning the unit and trying another one. Again the Sony support people will be able to advise.
[/quote]
Just to let you know that (as mentioned on another thread on this forum) AV Forum has a very lively thread running about this very subject, worth a look:
http://www.avforums.com/forums/showthread.php?t=606120&highlight=sony+870
There is a concerted campaign by some people on that thread to contact Sony on their freephone number and get a reference number for each machine with the EPG link problems so they have to examine the fault properly... I bought a 970 just after they came out (pre WHSV review) and have had the same problems with series linked and epg linked recordings.
