johno5585:
Does anyone know what settings were used when this tv was tested because my picture is poor, or does any one have recommended settings.
Help would be realy appreciated
THANKS
Hi there, I have had the same TV for almost 2 months now and have been really happy with it. The user guide could be more informative and, er, friendly but generally helps with the set-up. However, the default settings can need some tweaking, even if they are quite sensible.
I found that a couple of searches on Google found some useful advice. Try the another site posts - there are various recommendations to try out. Since the other half is comfortably ensconced on the sofa watching Grey's Anatomy, I am not about to risk life and limb by trying to check on those I tried and kept!
One thing I would say is that you will get quite a variety of quality of picture that has become much more noticeable now you have the Sony. Programmes from the States seem particularly prone to this. I have fairly natural settings, which makes some States-side viewing slightly washed out. That said, nature programmes on HD are fantastic.
There is a chance, I suppose, that there is a problem with your TV but I doubt it. Where are you getting your signal from? Ours comes from a Virgin V+ box. Blu-ray and standard DVD are outstanding.
You may also want to check out advice on power supply and interconnects for getting the best out of your Sony (but watch out: debates get heated on those subjects - you have been warned!)
